With my Econoburn gasifier ordered, I now need to arrive at a plan for storage- which I want to be as big as possible, to maximize efficiency.
I've been leaning towards pressurized in the last few days, but am also beating my forehead against the constraint that my old house's cellar is accessible only via a bulkhead hatch 48 inches wide and about 5.5 feet long. I'd never get a 1000 gallon propane tank down it, and am not sure even if a 500 would slide in without running into things (I sure don't want to discover it won't fit after I bought it and have it halfway in!). Headroom is less than a newer house, too, so that all is starting to push me back towards un-pressurized storage, maybe with flat plate heat excehangers.
For open storage options, I know the STSS tanks are out there, and they're probably OK if you want an off-the-shelf ready-to-go unit, but after looking at them in person at Tarm USA, they just strike me as too Rube-Goldberg for my preferences, given their very substantial price tags).
So here's something I ran across that has me __really__ intrigued: A polypropylene modular septic tank, shipped as flat panels that are assembled on-site using stainless screws. Unlike a lot of the plastics like the more common polyethelene or fiberglass resin, Polypro _is_ rated to handle 200F heat for long periods of time. In digging around on tank manufacturing companies' online literature, I found that polypropylene tanks have been in use in some instances for decades at 200F temps for metal finishing tanks (full of caustic liquid) . So the polypro material seems able to handle the temperatures-- as long as the specifics (seals, etc) of this make tank are also up to it. I am going to contact the manufacturer to ask some more, but in the mean time, I wanted to "float" the idea here to get suggestions, constructive criticisms, and the like. I know I'll need to insulate, too, but can handle that separately.
so here's the scoop on this tank I'm looking into
(broken link removed)
and
and an article (skip the intros on other tanks and go down to the heading of "Copolymer Polypropylene tanks")
http://www.gradingandexcavation.com/ow_0507_septic.html
Again, please "fire away" with suggestions, observations, constructive criticisms, etc. Thanks, as always, for all the shared wisdom & ingenuity around this place!
Trevor
and
Trevor
