The damper in the flue (flu?) is weighted such that when you "tilt" the lever, it's either completely closed or completely open.
The metal plate that is the damper is not completely centered within the flu and when I dry fitted the double-wall stove pipe, it interferes with the damper being able to close completely or open completely. I can, as a result, install the pipe with the damper open, and I can even close the damper, but if I use too much force closing the damper, it becomes wedged beneath the inner lining of the pipe preventing me from opening it until I lift up on the pipe---an action I will not be able to perform when the pipe is permanently affixed.
My plan is to apply a stopper (externally) to prevent the damper from being closed too far, thereby avoiding its getting wedged under the pipe.
My question is, what is the actual purpose of this damper and am I likely to have to use it routinely, or should I just expect that it is to be left open all the time. Am I correct in assuming that the damper is just there to snuff out a fire in the presence of an emergency?
