E
elkimmeg
Guest
This is an attempt to move and start a new post originating from
Lots of questions about soapstone stoves…long Post
https://www.hearth.com/talk/threads/3937/
After a lot of discussion it was determined that Struggles had a decent stove but never maintained. He was experiencing almost runaway fires. and planned to buy a new soapstone stove
With our help ( forum members) Sepecially Dylan and hopefully others the process has begun. He was able to get the gasket kit for the stove from
http://www.discountstove.com Ny next post is a continuation of how things are going and where struggles progress has taken him
The choice is yours did you also know that optional glass doors were made for that stove and possibly could be purchased, again a lot cheaper than new soap stone
That stove also has the option fire screen where the doors are swung open anfd you can enjoy the full fire view like any fireplace it would produce some heat
This stove has all that currently. I am in a bit of a pickle on what to do with it. I have heard before that it is considered a very good stove and that some say VC is not what it used to be.
Where could one find a manual for this stove? or least how to service it.
Since we have two small curtain climbers 3 and 5 year olds we do not open the doors and burn that way. I kind of like the idea of seeing the fire with the doors closed.
I am half considering if replacing ti using it in the garage but the stove is really in nice shape. I would really like to get a cleaner burning stove.
One note is I have not been using the down draft feature door as it seem to kind of turn to smoldering/ ash build up behind that panel. Should one be able to remove that panel with out totally taking the stove apart?
If one was to keep it should the whole stove be taken aprt and then resealed part by part and where does one find the correct sealer and how to clean the old sealer off. I will post a picture in a few mintues of this stove and how our upstairs unit is set up.
Signature
Vermont Casting Vigilant
(broken link removed) current stove/location
(broken link removed) upstairs unit. There is a bit of story behind this when a furniture decorator came out to access the layout etc of this room she suggested we PIANT THE BRICK, we never bit on that thankfully.
Chimney-chimney (broken link removed)
Signature
the secondary air supply is blocked so you are not going to get any use out of secondary air and dampering
Honest assesment These were some of the finest VC ever built they were truely air tight This is not the 70 version this is a couple of models of refinements.
the polution issue is not the same as the earlier 70’s stoves. If rehabed an and the opperator understands how to properly work that stove it can be damn near equal to EPA stoves
EPA stoves added secondary non adjustiable non user intervention secondary air to burn cleaner, they had to idiot proof stoves. If the user understands how to opperate that stove and regulate the air supply and damper and the stove with all gaskets working, air passages clear,and dry wood there is no reason one can’t approach clean burning.
your picture show the clasic example of needing to be brought to to spec, the whitish power like look at you oval to round adapter is from over firing
I believe your stove is a good canidate worthy of mantaince As for soapstone with children, they still can get badly burned from touching the glass or vent
Here is a link to a parts supplier for your stove plus an exploded view of your stove parts Like I said it maybe possible to swap doors to glass doors for viewing
Also check this web site for older parts the Woodsman is a wealth of knowledge concerning your stove and another parts supplier.
Members here and myself can help instruct how to go about replacing gasketing Read my wiki about primer to purchasing a used stove and light test your stove for seam leaks
You may only need gasketing. I can also advise hoe to re seam some area without requiring a total rebuild. If you are like me, I take great pleasure enjoying the fruits of my labor
If not into getting your hands dirty and ash dust then new is the way to go. IT just be me and my outlook. may be a bit not as modern I like clasic cars I like making things work I donot mind a mechanical challange. I hate to waste usable things and throw them away because the batteries died. But not all have this same feeling and not app the patience needed to get their hands dirty. We have become a disposable society, where little is repaired but replaced I’m from a differnt school of thought but I ok with the modern disposible society they supply me with my tractors lawn mowers chain saws excersize equipment for my wife My autos It works for me
Signature
struggle
Boy oh boy you are tugging at me now to keep it. I am almost sure at the bottom of the stove on the front the sealant is going to need redoing and other places as well. The gasket to the griddle (now I know what it is) Is hard and the seal on the windows clearly are not sealing the best now that I know a little more at what to look for. One concern would be taking it apart and broken fastneres along the way.
As for getting a little dirty I am a Master ASE auto tech so that is no problem.
I guess I am kind of hung up on the soapstone stove for looks and quality of burn time, but I am really rethinking this think now. Money is there to replace this stove but now am on the fence on what to do.
I am going to check this site out you linked.
I just am not real big on leaving the doors open but would rather
Signature
Signature
Signature
struggle
