another computer thread
fbelec
3,689
Massachusetts
has anyone out here ever replaced the bad caps on a dell motherboard? i have a gx620 ultra small. i guess the heat gets to them. thought it was my power supply but that check out with a green light and 12 volts. the computer does not turn on. when reading up on it lots of people having trouble with caps getting to hot and bulging or bursting. i have a number of bulging and a couple of burst ones. amazon has a bag of high temp caps for 10 bucks i'm thinking of giving it a go.
frank
You will need the proper size of caps for the replacements. A slight change in the inductance from a cap will make the motherboard go wonky.
Haven't done it. I have a collection of GX280s. When one fries the caps and the fan goes nuts I just strip the drives and memory and stick'em in another one. Bought five from the local school division for $25 apiece three years ago.
Down to my last two.
Ya have to be pretty good at soldering. You either have to have everything in place and at the ready and be real fast..or you have to do the proper use of heat sinks. Heat kills caps.
I always "cheated" when replacing them, - - trim off leads closest to component and solder new part to the old leads.
Reactions: Jags
the way i was trained was to put the part in the board flip the board upside down and fast and not to much solder. to much solder makes a mess and takes more heat. and or use the clothes pin type heat sink
Reactions: Jags
Yep - that is one method. The way retired guy was explaining gives you a little extra wire to deal with, which can be nice if you have the room.
