For those of you with airwash systems, when you say your glass stays clean, or you can burn hotter (if dirty) and clean the glass, do you mean your glass is really clear or alittle hazy clear? The reason I ask is on my new Regency insert i1200, my glass is not clear, clear, nor is it sooty dirty, it is just annoyingly a light milky haze that does not burn off...it just stays hazy or gets even hazier as I burn continously.
I had mentioned in my very first post that my glass wipes off very easily with a wet paper towel and water. There is no smoke what so ever out of chimney, so I know it is burning clean, and I checked moisture in wood. This insert was installed in to a Majestic RC-36 prefab (with 6" ss liner). I know thay tucked some insulation that came with insert around it then installed the faceplate. The draft is great and no problem starting fire. The haze is mostly oval left to right... The top, bottom and corners (2 inches or so) stay clear.
It's not horrible, but it just seems as if airwash is lacking, unless it is just the unit itself can it have anything to do with the installation? Does anyone else with this insert or other regency inserts have the same issue? And those who have airwash, does your glass stay really clear or somewhat clear? I may be overthinking this and it may be normal. I just want to make sure it is not the insert itself that is faulty. Thanks for listening.
