Hi I have been reading all about knock-offs and the old Defiant stoves on this forum. But still have a question but let me first introduce you to my duplicate.
I just wanted to add my knock-off to the collection. I am not wanting to identify it as the stove name is still on the label but can't read all of it. It was tested in 1980 by the PFS Cooperation which at this time was in Madison, Wisconsin. It is from the Taiwan Fita Industry and it has a 7-inch oval flue on the top. It does not have the slight orange peel look on the surface or what some of you called modeled look. The casting is different from the Olympic Crest and the Scandia 315. It has a rectangular square casting on the sides and off course it is the same size as the Defiant and very close to the older models. It does not have bricks on the back wall but there are bricks on the bottom. It also has writing on both the top front of the stove and above the side door which something I have not seen in the other knock-offs. The man I spoke with at EPA said he was surprised to see my stove was tested. I realize that the test may not be the standard for today but it did past the testing in 1980.
I have contacted Vermont Castings and they sent me the manual for the 1975 model Defiant. I also am aware of how some here feel about these knock-offs as I have read most of the threads on these stoves on this forum. I have to much invested in this stove to be discouraged about it. Please try to be as upbeat as possible with me. I did not see the Taiwan stamp on the back until I had it all taken apart so I have given this stove a face lift.
I have made a whole new damper with ¼ steel and better rod for turning it. Then I bolted ¼ inch steel plate to the interior wall as it was starting to crack. I had to do some fancy slicing and bending to match the curve shape. Then re-drill the holes in the bottom 1/4 plating of the inner wall were the holes were in the cast iron.
In the pictures you will see my fancy silver acorn bolts on the doors. I had to drill through the doors as the bolts were broke off I did drill them out but the tap for threading was tapered and the holes were not deep enough to make it work so I drilled out the doors and put on these fancy acorn nuts to fasten in the new ceramic glass windows.
But here is my question. I have read on this forum about people have trouble getting the secondary burn to work but I have not really found what a secondary burn should look like. In my own mind I have an idea but it could be a misconception. I have never had stove before with a horizontal burn. I don’t have a heat gauge. I do get a hot bed of coals in the stove and then close the damper. I do get a nice red glowing coals with very little flame until the logs burn down. The coals seem to be burning from the bottom up. There is no smoke coming from the outside stove pipe. I have two 90 degree turns in the stove pipe which is about 15 feet from the stove to the top. I have reduced the pipe from seven to six inch. It seems like I am getting a secondary burn but I don’t see anything going into the secondary burn chamber. You might ask about the bi-metal thermostat? I keep it wide open until I get things going and then close it half way after when I move the damper in the up position. But I am still in the process of making a box for the thermostat after reading the comments on this forum. I have also experimented with the keyhole air intake on the end and find it works better if I leave it open.
I made this long because I have noticed what questions you ask so I tried to cover them all in this post.
How does a person know if the secondary burn is working?
