I have a cast iron wood stove (Vogelzang BE-42E) in my shop. The previous owner used it, but the outside portion of the stove pipe had fallen off. This year I decided to install the outside portion of the chimney pipe which involved a 90 degree elbow to link the horizontal pipe exiting the shop to the 4’ vertical pipe that takes the exhaust smoke out over the roof. The pipe is single wall, with a press-together seam down the length of each 24” section when connected.
After a rain, the shop floor has a puddle of water outside of the stove, and the inside is wet with puddles. No water seems to be on the outside of the pipe. I sealed the gaps where the pipe goes through the wall joint so there is no gaps left. Last night and today it rained again (since my sealing efforts 2 days ago) and it hasn’t helped at all. But now I believe the water is coming solely from inside the single wall pipe. Must be seeping in from joints where they connect (I sealed some of those yesterday at the point where the pipes connect to each other - but not all). I did not seal the long edges where the single wall pipe snaps together to actually form a “pipe” as I didn’t think that would be necessary. However, I’m stumped as to how the water is coming in. I have a pipe cap installed on the top of the pipe, and with as much water as there on the floor is I can’t imagine it is where all the water is coming from. My only thought would be that it’s coming in from either where the joints connect to the next pipe, or some health through the seams or the pipes join together to form a pipe. The crimped ends of each pipe or facing down, or more precisely, towards the stove. I’ll try to attach pictures of my installation. Any thought would help as this will rust my stove in a hurry, as well as flood me out! Thanks in advance!
Mark
![Another “water leaking into stovepipe” question... Another “water leaking into stovepipe” question...](https://www.hearth.com/talk/data/attachments/274/274339-8ba03cb7c7cf821a1e7e8d89ea785fb7.jpg)
Mark
![Another “water leaking into stovepipe” question... Another “water leaking into stovepipe” question...](https://www.hearth.com/talk/data/attachments/274/274336-698785bf3a358f845c8d08e025f4571c.jpg)
![Another “water leaking into stovepipe” question... Another “water leaking into stovepipe” question...](https://www.hearth.com/talk/data/attachments/274/274337-1dfc0bac7e3286c2caf48e1045e82841.jpg)
![Another “water leaking into stovepipe” question... Another “water leaking into stovepipe” question...](https://www.hearth.com/talk/data/attachments/274/274338-a1c22b9c3018064e36f7e478ba4f07b1.jpg)
