Angle of rods when cleaning insert from the bottom
NoGoodAtScreenNames
491
Massachusetts
I’m going to try cleaning the liner on my insert with the soot eater for the second time. When I did it the first time the rods got a little banged and scratched up entering the collar since that was the area that it pivoted to create the 90 degree turn upwards. I can’t keep the drill inside the insert pointing up without creating gaps in the cleaned area. It would be something like 1 foot cleaned then 2 feet uncleaned.
I was thinking of building a little rig with some left over 1.5 inch pvc I have left over from the pool to soften the angle and get it to straight up by the time it enters the liner. Basically two 45 bends and a piece of some flexible pvc enter the collar to cushion things.
What do other people do to keep the rods at a good angle or am I over thinking things?
We use a peice of flexible electrical conduit to run our rods through.
Thanks. Seems I’m on the right track. I’ll see what kind of over engineered contraption I can rig up for this.
I isually only use it if i am going through a tee. Inserts are usually fine. I also use it then because i can plug around it to contol dust
