Really...I'm going somewhere with this.
At some point, our weekend house(a-frame) had a chimney exiting the center of the peak of the roof. It's no longer in that location. This past weekend, I took down some ceiling tiles someone had put in the loft; and that exposed part of the old chimney setup. It appears to be a roughly 24" section of Metalbestos piping. Right now, when you look up, you see the base of the exposed pipe and the pink insulation someone stuffed in there. Is there some type of cap or plug I could get for it? I just need something to make it look "OK" for the time being. I'm thinking next spring I'll have a roofer come out, remove it and cap over the area where the pipe was. There's no way I'm getting up there...that roof is steep!
The pipe has a 9.25" outside diamter and those Metalbestos style "tabs" for linking the sections of pipe together.
