american harvest 6500 mf stove
Is this what you are looking for? These have worked for my 6500 even though it says 6300.
  • 6300 4 digit with C code.pdf
Not sure what "mf" stands for but here is a manual link without the "mf" if your looking for that. Also not sure what you mean by programming/reprogramming.
http://www.usstove.com/resources/OwnersManuals/English Owners Manuals/6500.pdf.
i have owners manual thanks, but what i'm looking for is this computer reprogramming codes that run the stove in auto mode. right now if and/or when the firebox gets too hot the auger delay kicks in, which is good, both room air fans should operate when this occurs. only 1 operates on my stove. both fans should run also when stove is shutting down for cleaning , at least till firebox temp reaches a certain level, my stove shuts 1 fan down as soon as i hit the off button. something is not set right in the programming.
I believe I got that info from the "I Burn Corn" web site a few years back. That site is down for repairs I believe I read somewhere on here. A few people on here are missing them and have been wondering what was up with them as well.
It sounds like you are looking to increase your duct temp which I can only guess will come from increasing your pellet feed rate so long as you have everything else adjusted and running well.
Hopefully when they are back up and running you can get the answers you seek.
Good Luck,
Dave
