Hi All,
New member here. Spent the past few days searching the Web for some answers about my stove and found a wealth of information on this site. Actually learning some good information completely unrelated to the issue I was looking for.
Definitely appreciate the knowledge base here so far! However, I think I’m having a problem that is unique enough to not be prevalent in the search results.
I have an American Harvest (USSC) 6039 multi-fuel, and it’s the early model with the “A, B, C” control panel. Unit has operated pretty much flawlessly the past 7 seasons, consuming roughly 2 tons of wood pellets per season. I’ve had to replace the usual suspects such as the agitator motor and the auger motor, each twice.
Just recently the stove started running erratically. Best I can describe it is like the voltage drops off for a split second then comes back. Think of a something running steady and smooth, then cutting out sporadically but frequently. Then it runs smooth again for a while.
Well now when it starts to run weird, it will sometimes actually set a code of “E” in the heat range and “1” in the blower speed. From what I can tell this is a high limit switch issue. Typically stove is running on heat range 1-3, and this “E-1” error pops up well before anything seems to be too hot to warrant a shutdown.
Stove has had a thorough cleaning just 2 days ago, including brushing of the stove pipe and vacuuming out behind the cleanouts, brick, etc. No improvement.
I have 2 of these same model stoves, so I shotgunned a bunch of parts at the stove I’m using now from the other functional stove in my vacant residence. I know the “spare” stove is functional as it was just running over Thanksgiving without issue. I swapped over the control board, high limit switch, and exhaust blower. All same model OEM parts. No improvement.
Even tried to bypass the high limit switch with the paperclip trick. No improvement.
Anybody ever run into something like this? Any help tracking this issue down is greatly appreciated!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
