Last year I bought my first pellet stove, and had nothing but issues after 5-6 months using it because of apparent bad control boards, and admittedly partly because I never used one before. But, Hearth replaced it for me free of charge because I had to replace every internal part within the first year of owning it. Both models have been/are PelPro130's
1. Finally installed the new one, and it doesn't seem like it's throwing out as much heat as the first one (really haven't let it run much more than an hour so maybe this is in my head, guess I'll find out when I get home today).
2. Additionally, this one seems to leave the house smelling smokier. I don't recall the first one making the house smell aside from the first use, or user error after that - so unsure why this is happening?
3. Are these things safe to keep running unsupervised? I.e. while sleeping, or when I'm at work?
I fired it up for the first time and let it cure for 30 minutes and the expected curing odor/smoke occurred. Turned it off until this morning and after it got going again, the vents where the hot air comes from also had the slightest bit of smoke coming out during start up. Eventually it quit smoking but the smell persisted. Turned it off, went to work & when I went home for lunch, same thing again. Tiny bit of smoke with the odor. I don't recall this happening with my first one but I've never owned a pellet stove before 2022 so I don't know if I'm using it wrong or hooked the second one up wrong, or maybe this is all normal?
Took the old stove out, and put the new one right in it's place....nothing was changed regarding the OAK or exhaust vent. Between removal and re-installation we cleaned the exhaust pipe that goes through the wall out entirely, including the ash catcher on the outside of the T fitting. We did not clean the 5' vertical part that is outside. Stove is vented straight out the back, through the wall, up 5' and terminates, like the attached photo (not mine, just as reference).
Trim is set to 0.
Flame seems pretty large - flickering above the feeder tube and out of view of the glass - also attached. Not sure if this constitutes as a lazy flame, or not? Also pretty sure that flame was during the start up sequence on it's initial start up if that makes a difference.
Lastly...the glass seems a bit sooty. Maybe it's normal but after 2-3 uses there is definitely soot accumulating on the glass, some larger specs too. Inside the baffles is mostly fine ash, with a few pellets that didn't make it into the pot being less fine ash.
Think that about covers it all...does this sound normal?
Can I provide any more info?
Anything I should try tinkering with or fixing first?
![[Hearth.com] Am I Using This Right? Pel-Pro130 [Hearth.com] Am I Using This Right? Pel-Pro130](https://www.hearth.com/talk/data/attachments/316/316470-05ba3fd5e7cd1a359ad862dc8a7c0cc4.jpg?hash=gXkb7SdGSF)
Trim is set to 0.
