Am I missing a nut? Enviro M55 FS Steel.
DevinM88
25
Western MA
Please take a look at the attached pic. It appears as if I'm missing a nut :confused:. Just above the auger in the pic (at 12 O'Clock), I see the end of a machined bolt without a nut. Comments?
  • Am I missing a nut?  Enviro M55 FS Steel.
Yeah, that's normal. I forget what exactly that screw holds (probably the auger motor plate), but it does not need a nut as it grabs the steel plate. I took it apart some time back and here are some pictures. You can see the hole where the bolt goes into. I will double check tomorrow that is doesn't need a nut.
Reactions: DevinM88
