Hi all. I bought a house last year that came with an Earth Stove Cat insert and I'm new to all of this and just want to make sure I'm doing everything right.
Yesterday, I relined the insert with new firebrick and removed and cleaned out the combustor the best I could. Huge difference before and after. It was really clogged when I removed it.
With the bypass damper open and the air control high, I use one duraflame firestart log (really small) and build kindling sticks (bought from lowes) above and around it in a grid pattern. I light it and when it gets good and hot I throw a small log on top and when that starts burning I'll throw another small log on. As it gets hot and starts burning I obviously start putting bigger logs on.
Once the cat reaches around 500-600 degrees I close the bypass damper to engage the combustor. However, once I do this the flames almost disappear. Is this normal? Is it because the wood isn't seasoned well enough? Occasionally a piece of wood will have moisture bubbling on the end which obviously means it's not seasoned well.
Also, once I turn the blower on, the temp usually drops to around 400 degrees. I turn it off and it goes right up to 1000. If I move the air control lever to the left (low) it seems to suffocate any flames that were dancing. I almost never move the air control to low.
Any tips, advice, suggestions are greatly appreciated. Thank you.
