almost 1 ton
newguyjoe
113
Monroe,NY
So im almost through burning my fisrt ton through my Enviro EF2. is there anything besides the normal vaccuuming and cleaning that i should do?
Thanks
Joe
Hey Joe,
no, just the usual cleaning.
My Astoria doesn't require a "major" cleaning until 2 tons, or yearly...whatever comes first. I've gone through almost a ton too, so i figure a big cleaning sometime at the end of Dec. probably (I'll pull the blowers then). Does your owners manual list any kind of cleaning schedule? If so, follow that.
My Astoria manual DOES state " the more often the stove is cleaned, the more efficient it will run".
Make sure the stove is ready tonight...it's going to be COLD in SE New York (22 degrees).....brrrrrrrrrrrrrrrr. At least we're not in Minnesota.....I saw 1 degree there this morning on the weather site. YIKES! :gulp:
Same here and I've been running it virtually continuously since the beginning of Oct, with a 2500+ sqft house.
I started burning mid-october. When I'm home, I usually have it on the highest setting. When I'm not home or sleeping, I have it on lowest setting.
Currently about 15 bags shy of a ton.
Yep 1 ton here gone... Hey if your a pellet pig and you have 4-5 tons on hand and you use 2.5 tons do you get thrown out of the club????. inquiring minds want to know. onk oynk...
woodsman23 said:
....Hey if your a pellet pig and you have 4-5 tons on hand and you use 2.5 tons do you get thrown out of the club????. inquiring minds want to know. onk oynk...
No Woodsman, you only get thrown out for not paying your dues......hmmmmm, lemme see here.....Woodsman......nope, haven't got the check yet. You're on the verge of getting booted!!! :lol:
Get that check out ASAP (I take PayPal too ;-) )
On the contrary, if you have 4-5 tons on hand and only use 2.5 your elevated, because your hording for two years not one :)
Oh yes the check ummm yeah it' uh uhh it's in the mail yes the mail i swear. I even put something extra int here for you!!!!! :ahhh:
Bushbuck said:
I am at about 2.5 tons used so far..
You live in a wind tunnel??? :) Oh, wait, you must have been celebrating at a pellet bonfire for the past two months ;)
I don't even know a stove that can feed that fast.
Fess up!
Fess up!
I think "a stove" is the answer there, we burn more than one stove.
well I only have one stove and through 83 bags so far or just over 1 1/2 tonnes.... 1800 sq ft and we have not used the furnace this year yet :) and its been cold up here....
Thanks
Joe
and Joe my dealer said at 50 bags (1 tonne) pull the bafffles and vacuum in behind which I did
"Make sure the stove is ready tonight...it’s going to be COLD in SE New York (22 degrees).....brrrrrrrrrrrrrrrr. At least we’re not in Minnesota.....I saw 1 degree there this morning on the weather site. YIKES! " - Macman
My thermometer this morn in SE MN: +1.6
It's just getting balmy here...........
at that temperature we open the windows to aair the house out while its warm out %-P
