All one needs to know about..........
MCPO
........putting a stove in an uninsulated basement. And this is primarily aimed a wood stove installation . I`d have to think a pellet stove would be worse.
(broken link removed to http://www.woodstocksoapstone.net/pages/basement_install.html)
Interesting. I knew it was bad, but I didn't know it was THAT bad.
My question now is, "should I insulate my basement?". it is unfinished, utility/storage space, 8" poured concrete, and unheated, except for whatever leaks out of my furnace and ducts. that is...when I run the furnace, which isn't much. So it gets damn cold down there. I'm wondering if there would ever be any return on the cost of insulating it, in terms of $ or comfort.
fwiw, the ceiling is insulated w/ fiberglass.
Water pipes used for heat and domestic hot water , and heat ducts should be insulated for efficiency regardless of whether the celler is insulated or not .
If you don`t use your cellar there`s no real pressing need to insulate it but it can`t hurt , although once you do insulate you will probably have to be running a dehumidifier in it all summer long. I think the floor is a consideration too when thinking about insulating the walls. It also must suck up heat like a sponge.
My basement is insulated and carpeted thus very easy to heat.
