First time poster...my apologies in advance for the long post, but I've read much on the subject and want to get comfortable with my proposed alcove design...and get other feedback from more knowledgeable Hearth members. Hopefully, others will learn from this as well.
Wood Stove: 2021 Lopi Evergreen stove with legs (not the pedestal), fan and OAK. Placing in an alcove is permitted by mfr. I want the alcove bc I like it, and think I can make it work effectively to heat the house. I am hopeful that the stove will be the primary heat source in the winter; will supplement with propone furnace, as needed.
See attached pics to visualize what I will try to explain below.
New house with exterior walls built with ICF (insulated concrete forms), 6" concrete sandwiched between 2 1/2" of eps foam on each side.
Proposed alcove is to be built in great room with 9 foot ceilings. Alcove is framed with wood 2x4s but I can reframe it with steel studs, if needed.
RO Dimensions: 66 inches tall, 72 inches wide, and 27 inches deep. About half of the stove will sit inside the alcove and half outside. One of the attached pics shows placement.
According to Lopi owner's manual, if the ceiling of the alcove is less than 84", then the alcove requirements must be followed. I want to make it a non-combustible alcove which requires 3.5 inches of non-combustible material and 1" air gap.
My plan design is as follows: Line the interior of the alcove with 1/2 inch Durock fastened to the wood studs. This would run from floor all the way up to 9' ceiling height. I would also attach Durock as the substrate for alcove ceiling (66" high). Then 1 inch air gap created with copper pipe or ceramic spacers. Then 2 inches of qualifying non-combustible material (not sure what this will be yet, but open to ideas...(more layers of Durock, some kind of mortar, etc...but weight may be an issue see below). Then the stone veneer 1.25 inches limestone rock plus mortar (2 inches combined) for a total of 3.5 inches thick. The rock on the interior of the alcove will go just above the opening or ceiling of the alcove, 66 inches (not all the way up to the 9 foot ceiling). This is to save on weight and cost. To be clear the stone veneer will be the surface closest to the wood stove. This stone veneer will also be set on the front of the alcove facing the great room. A non-combustible mantle will be attached above the alcove opening, about 6' from the floor. The stone veneer will continue up to the 9' foot ceiling above the mantle with sufficient room for an air vent for heat to escape. And there will also be stone on each side of the opening facing the room. The ceiling of the alcove will slope upward from the back wall toward the front to allow hot air to escape more easily. On either side of the alcove will be built-in window seats, see the pics, and will be regular drywall with a vent on each side to further allow heat to escape. The stove also has a blower and there is a ceiling fan in the room to move the warm air around. Under the stove will be ember protection: sheet metal under tile or slate which is all that is required by the mfr. for this stove. R-value is not needed. It will extend at least 16 inches in front of the stove. I will run regular stove pipe up to the alcove ceiling (66') then convert to chimney pipe to mitigate heat b/c the surrounding walls in this space (including the ICF foam wall) will only be covered with Durock (no stone in this space). Again, this is to save on the weight and the cost. The chimney pipe will be rated for 2" clearance to combustibles.
I would like some feedback on this issue specifically.
With this design, all the clearance requirements are met (even after taking into account the 3.5 inch thick walls), i.e. there is sufficient clearance between the stove/pipe and the non-combustible stone surface closest to the stove (which is what tech support told me was required).
I've spoken to technical support at Lopi (Travis Industries) and they gave me helpful info. As near as I can tell, this design complies with the written instructions, as well as the verbal discussion we had. But I would like to get feedback from the pros in this forum.
I am having my engineer look at whether the floor needs to be supported. Altogether the finished alcove, wood stove, mantle, and three average-sized people warming themselves will be about 5,000 lbs. There is a basement under this room, but it's finished. Adding columns and beam supports will be destructive and a pain, but I'll do what I have to do.
Any thoughts, feedback, comments on this design? Safety is foremost on my mind! If weight is an issue, I will re-frame the alcove with steel studs, in which case, as I understand, I won't need the 3.5 inch thick alcove walls. The rock veneer embedded in mortar (about 2" thick) should suffice. Do I understand that correctly? The back wall is an ICF foam wall. It's sorta the wildcard here. I plan to cover it as described above with the 3.5' of non-combustible material regardless.
In terms of the heat, will the limestone veneer be ok for this application (1.25" thick)? Or will it be too hot in the alcove? A caution was raised in a couple articles I read (not on this site), so I thought I better get some feed back on this issue, too.
What are your thoughts?
Thanks in advance for all your help. I appreciate it tons.
![Alcove Design for Wood Stove in ICF House - Feedback? Alcove Design for Wood Stove in ICF House - Feedback?](https://www.hearth.com/talk/data/attachments/307/307595-e6ea622af2c6776a2d90f129e86175d2.jpg)
![Alcove Design for Wood Stove in ICF House - Feedback? Alcove Design for Wood Stove in ICF House - Feedback?](https://www.hearth.com/talk/data/attachments/307/307577-754853b53d360a68492e38e2f88d7836.jpg)
![Alcove Design for Wood Stove in ICF House - Feedback? Alcove Design for Wood Stove in ICF House - Feedback?](https://www.hearth.com/talk/data/attachments/307/307581-503a148f6d012cc910a879c7374b8fcb.jpg)
![Alcove Design for Wood Stove in ICF House - Feedback? Alcove Design for Wood Stove in ICF House - Feedback?](https://www.hearth.com/talk/data/attachments/307/307583-dc538733b44428e9e54af85c66395fe3.jpg)
![Alcove Design for Wood Stove in ICF House - Feedback? Alcove Design for Wood Stove in ICF House - Feedback?](https://www.hearth.com/talk/data/attachments/307/307588-75c9436bb3744035230a4e30080b50d6.jpg)
