Hi All,
I have an air wash question on my manchester. Long story short been battling the dreadful stuck air control lever issue. I had installed the repair kit Hearthstone has and didn’t do much. I’ve had the stove apart numerous times and tried a few different things including polishing the pushrod which helped a little on making the air control smoother to operate. End of the day the air wash flap at the top of the stove is connected to the flimsy pushrod that moves the flap open to close as your moving the air control. If i manually hold open the flap with a screwdriver the air control operates smooth as butter. Question is i can cut a tubular steel rod and wedge it so the flap for the air wash stays all the way open regardless of the air control lever. This would leave the flap always wide open when i’m running the stove. What’s the negatives of running the stove with the air wash flap always open? I can’t think of any reason how this would harm anything? Any thoughts are appreciated. Pic of the air wash flap included. Thanks
