Air to Water Heat Pump Seminar
peakbagger
8,979
Northern NH
I get invites to free online seminars on occasion. This one showed up today
Learning Objectives:​
  • An understanding of air-to-water options in the marketplace, including how its been adopted elsewhere
  • The key components of an air-to-water heat pump that make it the high-performing, energy-efficient system you need to include in your next project
  • Expected performance data from testing and real-world examples to set expectations
  • Different installation configurations available for air-to-water heat pumps with detailed schematics
John Seigenthaler is big advocate on air to water heat pumps comparted to conventional minisplits for heating dominant areas. (I dont think he is tied to this webinar). For those with radiant floors, walls and ceilings designed for low temperature supply water, its a drop in. For us folks with high temp emitters it may not be as good of a fit.
If I do another house I plan to go with low temp emitters and it would either be air to water or geothermal for a heat source with a wood stove for cold temps.
Where do you find the low temp emitters? My wife doesn't want to do radiant floor on the second floor, but likes the idea of retrofitting our slab.
John Seigenthaler is big advocate on air to water heat pumps comparted to conventional minisplits for heating dominant areas. For those with radiant floors, walls and ceilings designed for low temperature supply water, its a drop in. For us folks with high temp emitters it may not be as good of a fit.
Unfortuantely, "it" doesn't exist yet on the market here in the states. Or if it has arrived, do you have a link to this mythical air to water heat pump? I've been waiting a long time for it.
Reactions: SpaceBus
If I am not booked in a meeting I will be signed in to the webinar as I too have been waiting for the units to make it to the US market.
Reactions: Highbeam
