We bought a house earlier this year with an Esse Ironheart upstairs and a traditional masonry fireplace downstairs. The prior owner had the Ironheart installed, but never used it thinking the new stove might boost his sale price. We get noticeable smokiness when running the wood stove. Our air quality monitor shows pm2.5 levels spiking to >100 ug/m3 at the worst times. It’s worse but not exclusive to startup and refueling. There has definitely been an issue with cross drafting as the stove flue and chimney open right next to each other and some of the time the smokiness is worse down in the basement when the main floor stove is running. The downstairs fireplace doesn’t seem to cause the same issues, except for the cross drafting. The fireplace has an outdoor air intake while the stove does not and is not installed in a location where that is possible. We have a local installer coming out in a few weeks to help troubleshoot, but I thought I’d canvas for some ideas on things we can try in the meantime.
First, things we have tried:
- we are only burning seasoned wood tested at <20% moisture
- we build the fire top down to try to help get a good draft to start
- we manage the air intakes per the manual
- we wait until it’s burned down to hot coals to refuel, then open air intakes about 30 seconds before reloading
- we only have softwood (Ponderosa and Douglas Fir) to burn. If the solution is to burn only hardwood then it may not make sense to keep/use the stove at all, as the main benefit is “free” heat from timber that requires thinning on our property
- the damper on the downstairs fireplace is closed whenever it’s not in use
Any thoughts on other things we can try to mitigate this issue? While I’m aware that some pollutants are inevitable, it doesn’t seem like a modern wood stove should be this bad or so much worse than the old fireplace with a folding glass door.
