I've finally got my boiler plumbing all done. The local inspector now wants me to fill the system with air at 60 psi for inspection purposes. Couldn't that pressure mess with or screw up some of the elements of the system such as the expansion tanks, the pressure relief valves, the automatic air vents, the backflow preventer and the pressure regulator valve on the make-up/feed water line, and I don't know what else.
What do you recommend? Should I be disconnecting, plugging or valving off some or all of these items for the test? Any advice would be appreciated? Some of you must have had practical experience with this.
Here's an exact list of the items I'm most concerned about:
Extrol Expansion Tanks, SX-30V and SX-160V
Watts Automatic Air Vents, Series FV-4M1
Watts 0039QT 1/2 " Reduced Pressure Zone Assembly Backflow Preventer
Watts Feed Water Pressure Regulator Valve Series 1156F (comes set to 15 lbs)
A couple of standard 30 psi pressure relief valves
I have yet to do the final connection between the make-up/feed water line and our home's water supply. I thought I should air pressure test the system first before connecting the feed line. I'll probably have to connect that up too prior to inspection. I guess I should shut off the valve on the feed water line for the pressure test, as 60 psi is greater than the 50 psi of our well-fed water supply.
My boiler is a Solo Innova 50 and I've a 1000 gallons of storage. I assume the boiler, the w/a heat exchanger in the furnace plenum, and the Bell and Gosset Type Low Pressure BPX Brazed Plate flat plate hx to the DHW supply can handle 60 psi.
Thanks for your help.
Mike
Mike
