I have a long narrow ranch styled home. Fortunately, the fireplace is in the center of the house and the living area of the house is fairly open. I am planning to install an insert in the fireplace. I am leaning towards the Napoleon 1402 insert. It has a 2.25 cubic foot firbox, which is the size everyone here seems to think would be best for me. Output is 11,400-41,300 EPA and 70,000 Wold Steel Ltd. It is rated for a 1,000-2,000 square foot house. My house is about 2400 square feet. So I'm thinking I might be a little on the small side. I don't really know. I don't need to heat totally with wood but I would like to heat as much as possible with it. I'm in Southern West Virginia and the winter temps are generally the 20's at night and the 30's-40's during the day. Anyway, I am concerned about circulating the air in the house and I would like to avoid running the furnace fan.
My plan is to put two cold air return vents in the ceiling of the room the insert is in and then feed each one of them to opposite ends of the house through duct work in the attic. They would then discharge from the ceiling at each end of the house, to circulate the air. I would then put duct boost fans or something similar in these two ducts. Has anyone tried this before? How well did it work and is it something I really need to do?
Thank you in advance for your advice
Karl
Karl
