Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
The #2 error light comes on. Stove goes into start mode and then shuts down after 20 seconds. Replaced fire sensor, vacuum switch and check both room and combustion fans. Both are working. Thoughts?
isn't the flashing #2 a vacuum problem? Is the stove real clean? Have you checked to see if the vacuum hose is clear? Take it off the vacuum switch and blow into it towards the stove?
How old of stove? #2 is indication of low or no vacuum. Lots of glass on that model. Have you tried the bill test on the ash door and main door? Have you tried jumping the vac switch? If after you jump the vac switch and things start up you will have narrowed it down to vacuum loss somewhere. We Should get ya going with out to much fuss IMO
Definitely a vacuum issue. That stove also has an internal damper. Start with it all the way closed and open it slowly until it runs. Unplug and reset the board as you go along. With patience you will find the correct setting
Have you cleaned behind the firebox thru the ash traps? Tapped the firebox walls with a hammer to dislodge the ash that builds up inside the stove? Used a leaf blower on the exhaust vent? Just asking… my experience with these stoves sez most of the same problems come from a stove plugged with ash.
