Hi all, I have a modern house built in 1980 with a brick chimney coming out of the highest point. There are three flues, one is unused (it was for the furnace which is now replaced by a high efficiency unit that discharges elsewhere), the two existing fireplaces have been replaced by Morso 5660 inserts that have liners leading up to the top. The liners are not capped in an ideal way. The installer (out of business, of course) did not put in top plates, leaving gaps around the liners. The chimney is capped with a bluestone plate atop eight brick pillars. The brick pillars need to be rebuilt due to age. No big deal, it will allow us to install the top plates correctly.
My question to all of you is, my contractor feels that the pillars are not tall enough, but I am concerned that taller will make it less stable and what will it gain us anyway? He thinks it will lower the heat load on the brick and pillars, but I'm not so sure and in any event, I am by nature resistant to change. The pillars are now four bricks tall. Here is a photo from a few years back showing the chimney.
One thing is that the approach to my house is down a steep driveway, so while in certain cases, I would install aluminum caps and be done with it, this is my façade, so I want the keep the brick and the bluestone.
If it matters, I burn one of the liners at a light to medium load most evenings during the heating season, although if there is a power outage (once every other year) in the winter, I will burn full loads until it recovers (worst was ten days).
