Advice on older wood stove to existing masonry chimney.
BLG
16
Virginia
Hi everyone. I need a little guidance on installing my tiny all nighter woodstove. The building is a smaller 400 square-foot pool house built in the 1950s. It has a masonry chimney. Looks to be in really good condition and hardly used. The chimney is approximately 20 feet high from top to bottom and the stove will be in the basement of the small house. I would love to not have to put a new stainless steel liner in if I can get away with it. The dimensions of the flue looks to be about 8 1/2 inches round in circumference. Here are some photos and advice is greatly appreciated.
[Hearth.com] Advice on older wood stove to existing masonry chimney.
[Hearth.com] Advice on older wood stove to existing masonry chimney. [Hearth.com] Advice on older wood stove to existing masonry chimney.
Hi everyone. I need a little guidance on installing my tiny all nighter woodstove. The building is a smaller 400 square-foot pool house built in the 1950s. It has a masonry chimney. Looks to be in really good condition and hardly used. The chimney is approximately 20 feet high from top to bottom and the stove will be in the basement of the small house. I would love to not have to put a new stainless steel liner in if I can get away with it. The dimensions of the flue looks to be about 8 1/2 inches round in circumference. Here are some photos and advice is greatly appreciated.View attachment 324500View attachment 324501 View attachment 324503 View attachment 324504
That is an old unlined block chimney you need to line it with an insulated liner
Reactions: FTG-05
I thought so. How was it set up originally. Stove pipe to the concrete foundation wall and thimble? Anything else?
I don't know how it was originally or what was run into the chimney from where. But you will need a proper liner and a proper wall pass through. If it's a solid masonry wall a simple terracotta crock with the stainless run through is fine
Yes it is solid concrete with a terracotta liner into the flue. It is about 61/4" in diameter. So black stove pipe to stainless tru the wall and then connected by a T to the liner all the way up? Another question. Should I insulate the liner or not? Thanks
Yes you should insulate the liner
