- Feb 8, 2007
- 5
Hello all. I am pretty bummed to say the least. I purchased a nice insert and the liner kit. The 6" liner was too tight to fit down the chimney with the tiles inhibiting it so the liner store told me to simply ovalize it. I laid the beast out on my front lawn and rolled pvc pipe over it. IT WORKED! I was able to slide the liner down the chimney with no problem....until it got down to the bottom. Seems that the builder of my chimney made a small customization to the opening at the bottom. Even after removing the damper there is a difficult bend that the liner has to make. I had a friend stand on the roof and bounce the liner downward while I pulled it around the bend and it worked!
The problem: The insert's flue opening is on the top and because the opening of the chimney has a bend and is not straight down it is difficult to flex the liner almost horizontally to connect it to the top of the insert.
I am sure this description sounds confusing but I am hoping someone knows what the heck I am talking about or has had a similar problem. How the heck do I connect this liner to the stove? Do I dare make a sharp 90 deg turn and severly crimp the liner? My next idea was to cut away some of the mortar that is causing me to have to bend the liner around. A lot of the mortar came out but now I am getting scared that I may destabilize the construction of the chimney. Advice? Insight??
