I have a 1890 2 story colonial in NY, going to be remodeled soon with new windows. Downstairs sq feet roughly ~1600sqft, upstairs ~1400sqft.
Existing ~10year old stainless liner, oval, connected to original fireplace (roughly 9"x5.5"). Roughly 27' high.
Installer suggests running an oval liner of appropriate size inside this existing liner, and then insulating around it with poured insulation. Per my calculations a 5 in. x 8.15 in. should provide equivalent area to a 6" liner - provided it could fit. Questions are thus:
1) Do you think this is a functional solution if the appropriate size liner could be made to fit? The alternative is to remove the existing liner, which was apparently well installed and it might be a complex and expensive job to remove.
2) I'd welcome any recommendations on insert and insert sizing. I'd like one that qualifies for 2021 tax break. Thus far I am looking at Blaze King Ashford 25 and Lopi Hybrid Medium Flush (If I can find one!) I have radiators and a natural gas boiler. The living room where the fireplace is, is about 310sq ft. The stove won't really be used for regularly heating the house; rather more for ambiance burns and to complement the boiler/radiators when running.
Per the stated numbers, the Lopi puts out 2x the BTUs of the Ashford, but I don't know if these numbers will obtain; I also don't know if either stove is oversized - given that this is an old house, and not an open floor plans, I'm not sure how well heat will actually circulate and whether I risk overheating the room.
The only other inserts I've found that qualify are the regency I1500 and I2500, but both protrude a bit much for my liking.
