I could use an experienced opinion here. We are installing a second woodstove in the family room I’m building in the basement, and I’m on the fence about the size I should aim for. I’ve done all the on-line BTU calculators, but I feel the install situation is more complicated than those can capture. Real-life user advice would be helpful.
As I said, we are going with cast-iron for quick heat-up times. We really would like a Jotul. So…. F3? F400? F500 seems too big, but am I wrong? We don’t want to be cold, but we also don’t want to turn the room into the 9th ring of hell. If anybody with one of these stoves can give share their experience, I’d appreciate it!
Thanks,
-Ron
- Stove is mainly to keep family room comfy in winter. It won’t be lit until after school, and will be allowed to die overnight. Whatever heat it adds to the house above is a bonus.
- We are going cast iron, rather than soapstone, for the quicker heat-up time because of this anticipated use pattern. We want a Jotul (unless convinced otherwise…)
- Basement is 1450 square feet, but it is divided in half as in the image below. We really only care about heating the finished family room, but must compensate for the heatsink effect of the work-room/storage area in the unfinished side: the wall between is uninsulated drywall-on-studs.
- Basement has insulated pre-cast high-pressure concrete walls, with a concrete floor. It is set into a hillside: the back of the family room and the entire workshop is below-grade, the front walls and part of the family room side wall is above. There is no door at the base of the stairs, so heat will rise freely up that staircase; there is an interior-grade door at the top.
- House above is two floors with a cathedral ceiling main room, heated by a Woodstock soapstone stove and electric heatpump. That central heat does put out into the basement too, but only via too small vents (it is currently very cold in winter down there)
- Climate is Northwest Virginia. However, we are 2000 ft up a mountain, so it is probably one climate zone colder than you’d expect.
Thanks,
-Ron
