Hi folks, long time lurker, this is my first post. Looking for advice on rebuilding a Stihl MS310.
Its my primary firewood saw. I bought it used about 10 years ago and it has served me well (doing side work for years and now the last 2 years in a new house heating primarily with wood). I took down 3 trees in January of this year without any trouble, and then it sat for a couple months. When i tried to use it in March it would start just fine and run on half choke. Taking the choke off would cause the saw to stall out unless you kept your finger on the throttle. Obviously something is up...changed air fiter and fuel filter and cleaned the carb. I checked the fuel pickup line and it did not appear cracked, i even put my mouth to it and blew into it and it held pressure fine. I had picked up a new fuel line but saw no reason to try and mess with that since the old one appeared OK. Put it back together and there was no improvement. So i dropped it off my local small engine shop at the beginning of the month. He took a look and told me the engine is toast. He stuck a camara in through the spark plug socket and told me the piston and cylinder walls are scored pretty bad.
This is a real bummer becuase the saw always ran great. When this all happened i JUST missed out on a used MS310 on craigslist. I can get by and do some light work with my MS170, but i need a bigger saw to finish up some trees I've already taken down this year.
I am looking to you fine folks for advice with attemping to rebuild the engine myself. I'm reasonably handy but I will admit I don't have any experience with 2 stroke engines. I see there are plenty of available piston kits as well as complete assembled piston and cylinder kits (that are more expensive but eliminate the precision work of getting the engine internals correct.
I know i could go out any buy a new saw, but my nature is to tinker and try and fix things. The advice from my small engine guy is the older Stihl saws are better built that the newer ones anyway. I'll probably borrow my fathers MS290 to get me buy and I'll keep a close eye on craigslist for anything that comes up for sale. That being said I plan to mess around with my current saw and try and get it going again.
I'd appreciate any advice on tearing apart the 310 and getting it running.
Thanks!
Thanks!
