OK, so I attempted to re-gasket the loading door of my Progress Hybrid yesterday. As usual with me and this door, things did not go well. Tried to install the maximum density gasket Woodstock sent and couldn't get the door to close. They advised that you would have to push the door very hard to get it closed. Called my son in to help (he's 15 and not athletic). I'm 55, female, and fairly strong and brawny (peasant Polish, German roots), but probably not much stronger than he is. So, we're pushing for all our worth against the door when we suddenly hear an ominous metallic scrapping sound. Not loud, but we heard it. Jumped back to see what damage we'd done. Noticed that the nickel that was under one of the legs, is about an inch or so not under the leg anymore. My first thought is that #$%$$# we've moved the stove, all 700 lbs! It's sitting on porcelain tiles, and they do not appear to be scratched. That's puzzling, I was sure they would be. Now, I'm wondering if the nickel just shot out from under the leg and made the noise. Probably wishful thinking. Regardless, should I have the chimney sweep come and check the stove pipe to see if any is dislodged? Or just start up a small fire and see where the smoke goes? Any other suggestions/things I should check? BTW, this has earned me the nickname Incredible Hulk as well as some cred points with my son
