Do you plan to remove the whole topside chimney too? The ceiling support box was installed from above. Screws were threaded through the sides of the box into rafters. It holds the chimney to the top cap. All or nothing.
It would most likely take removing the chase and chimney on the roof, then removing the flashing to get at the support box. After removal a plywood patch would need to be nailed in flush with the roof decking and then new shingles woven in to cover the patch.
The chimney is supported by what you see protruding into the room. Removing the support means removing the chimney pipe, leaving a hole in the roof.
Will the gas fireplace need a vent?
I agree with webby try just pulling the chimney out the top. If it does not move pull the chase cover and see what is holding it. You may need to climb down into the chase to remove support brackets. Then cut the bottom off of the support box to get access to the screws holding it. Have a new chase cover made without a hole and patch the drywall.
I think you can call professionals and can discuss this issue with them. They have more appropriate advice for you. There are many chimney expert in long island, you can get help from there.
Thank you!If you haven't discovered yet, many of the posters in this thread and on this forum are professionals and even chimney professionals with superior qualifications and experience. These professionals are so obsessed with their profession that they are willing to come on to this forum in their spare time and give advice. Helpful and knowledgeable.
My experience with local, out of the phone book type, professionals is the opposite. Unhelpful, expensive, hacks. At the very least, the original poster of this thread will have the benefit of hiring one of them with an educated opinion of what he wants done.
Methinks that was a spam troll. There are industry experts here that have provided a lot of great advice. It's much appreciated.
