Hey Guys,
I've had almost a year long struggle of getting a wood heater for my house. I'm getting increasingly impatient as the process has become more and more painful. Here is how the long story unfolded… (TL;DR: scroll down to the bottom for my questions)
I started off looking at putting in some type of insert into my zero clearance fireplace. I researched all sorts of models claiming to be "zero clearance" approved; looks like I could at least meet clearances and dimensions with the Enviro Venice 1200. The insurance would not cover it without a licensed contractor. I contacted dozens around here and the most safe install would be to replace the whole chimney. At least $5K+, it could not be restored to a fireplace, and how well would a 1.85cf insert heat 2400 sq ft? Overnight burns? In addition several shops said it was against code without specifying details. So...
I started looking at EPA Fireplaces! I called and called to get an idea about pricing. I checked all sorts of dimensions and clearances. The FPX42 looked great, but all said and done, it would be at least $12K, multiple contractors or dozens of hours figuring out how to become a master mason after a 60hr work week. At that price, it made sense just to leave in this crappy fireplace and put a stove in another room.
So I looked around until I decided to see what the fuss was about BK. Then I saw, 30hour burn times, thermostatically controlled intake?! BK Ashford is the stove for me! I thought, I can just put this in the dining room at the other side of the house, keep that room at 80°F and the rest of the house can hopefully stay cozy around 70°F. I could just run the pipe straight up through the closet upstairs. I got three quotes for the BK Ashford 30, but no one could install here.
Then I got someone over to quote the install and as we started measuring, it did not look like that venting could work through the closet. I told him it was recommended to run it through the house, he said, “Nope, we won’t mess with that. We’ll just run it straight outside and along the house. We do them all done that way”. I asked him about doing two 45’s out of the stove and he thought that was strange as well. These guys have been around 30yrs, top ratings, are NFI, CSIA, everything certified too, not a crappy small shop.
Then he plugged the numbers: 25’ SS double wall “best”, smoke pipe, 2-45’s, wall plate, adapter, T connection, wall bands, 2-15° elbows (around the roof edge), and SS raincap=$3800 parts+$550 install fee+$75 permit filing! Plus stove and stove pad! So now I’m close to pushing $9K for this install. And in February they came and told me a total stove install would start around $5K! They are obviously padding the parts cost so they don’t have to ask for a $2k install fee. In comparison, the BK dealer thought the install would be about $6500 if he could install here. I got a top of the line Trane Central A/C installed for $6500, how much could a woodstove cost?
On top of this, we have an efficient NG heating running about $800/yr and my wife is working in 250mi away now until she can get a decent job back up here. We planned to stay about 15 years but now there’s a chance we could be moving in 5. I’m just dreading the thought of just being cold huddling around our smokey ZC fireplace this winter.
So these are my main questions (check out the image for info):
· What are some options for running the stove pipe through my house? What is typical? Could it even go straight through a bedroom?
· If I run the pipe outside like they want (2-wall stainless insulated pipe), will it draft efficiently and not get excessive creosote?
· Does the location make sense? Or does someone see a better place to put it? It would look weird right next to the fireplace and I'd rather it be hottest in a less used room.
· Any estimate how well will this heat assuming about 2400 sq ft decently insulated house? (will I make much back?)
Thanks in advance if you care to ease this painful process.
