Advance outside air pipe?
flashbang
135
NY
Hi,
Is there a flex pipe that will work to connect to the stoves air intake flange other than Harmans overpriced pipe?
The manual claims it needs to be some bastard size of 2 3/8 inch I.D. which don't ad up when I measured the flange unless it is thick and goes inside the flange instead of outside.
Will 3 inch flex aluminum dryer pipe work for $8.00 at the Depot? Open to all suggestions.
Thanks
Flash, the air inlet tubing is supposed to fit over the outside of the stove's air intake. The O.D. of yours is 2 3/8" ? Hmmmmmm most of them are 2".
Like this:
(broken link removed to http://cgi.ebay.com/Pellet-stove-outside-air-intake-kit-2-inch-_W0QQitemZ330346950962QQcmdZViewItemQQimsxZ20090724?IMSfp=TL090724168006r37126#ht_500wt_968)
Like this:
any of the air kits I've seen on Harmans, the flexible intake pipe fits INTO the stove intake nipple, not ONTO it, and yes, the part number for the intake pipe lists it as 2-3/8".......
I have the Harman OAK on my Advance, the flex hose fits into the air intake in the back of the stove, It came in Stainless I painted it black so it all matches.
2-3/8" = 60mm
I googled "flexible pipe 60mm id"
(broken link removed to https://www.europaspares.com/EXHAUSTS/EXHAUST_PIPE/GALVANISED_FLEXIBLE_EXHAUST_PIPE_5466.html)
