Not a comment about the wood, but i have to say, cutting down a tree in that manner is dangerous. The cuts shouldn't be at an angle like that otherwise the bottom may slide down and to the wrong side, sending the tree in the wrong direction. I realize it wasn't cut all the way through, so there was a hinge, but one of these days it might not work so well.
Should start with a wedge about halfway through on the side you want it felled to (check which way the tree wants to go). Then cut flat from the other side, leaving a hinge.
I wasn't to sure of the wood either as don't see a lot of that around here. BUT I did think the same thing as mentioned when I saw the cut. That long angled down back cut looks a little scary to me. Only reason anyone on here will say something is for your safety Mitch. Lots of good guys hangin around just lookin out for fellow firewood gathers.
Yes, the back-cut (cut 3) should be level. That is kinda the standard way for most folks. I have seen guys do it as you did too, and the results were the same.Ok, to clarify, the wedge "Cut" was made on the side the tree was to fall. Cuts 1 & 2. Then an angle, cut #3 down to the wedge cut. I like a slight slant to that cut. Are you saying a level cut is better as the number three cut? Thanks for the comments.
Sorry I wasn't around to answer back Mitch but looks like Midwest and Sav about summed it up. Just glad you have been okay to this point. I used to cut my back cut at a slight angle down as seemed like it made sense and most times will workout ok but it only takes that one that fools you and starts a little twist. See how that front broke away above your wedge cut. With a nice deep wedge and a straight in back cut you won't get that and you can hang out here with all your limbs intact.Ok, to clarify, the wedge "Cut" was made on the side the tree was to fall. Cuts 1 & 2. Then an angle, cut #3 down to the wedge cut. I like a slight slant to that cut. Are you saying a level cut is better as the number three cut? Thanks for the comments.
Remember to be "above" the wedge cut. Also, get felling wedges. You can make trees do things that they would not normal want to do. (and keep your bar from getting pinched).Thanks to all. I'll try a little more level back cut.
Typically. When you start getting around your chain, I don't want anything metal there.Is a felling wedge plastic ?
I had a Redhead snap off on me when I was getting some Silver Maple recently. I don't know how it happened, I just saw the broken-off stub in a cut.I make mine from hickory or hophornbeam (Ironwood)
I had a Redhead snap off on me when I was getting some Silver Maple recently. I don't know how it happened, I just saw the broken-off stub in a cut.Might have rolled the log over on it when it was in the cut.
Those woodies look awesome.I don't know if I could bear to paint 'em. Probably get lost fast if you don't, though. Do they pop out and fly around sometimes? I may have to try to make some. Got no band saw, though. Hmmm, Dogwood wedges...but you said that stuff gets smooth...
