adding storage for dummies
Outlaw
12
Central Vermont
Could someone please direct me to a good and hopefully simple plumbing diagram for storage when plumbed in sieries? The ATMOS is currently up and running in sieries, I am adding a 500 gallon propane tank for storage. I need a simple solution so I can add storage without completely replumbing everything.
On the beginning of the forum there are "stickies" the yellow messages there is plumbing there. If those don't help could you possibly draw your set up and post ?.... Then everybody is on the same page, so to speak...
Rob
I got stuck with a series hookup and put storage in. You can see the plumbing I used here http://www.woodnotoil.com/readarticle.php?article_id=3
That said, I wish I had switched over to a P/S plumbing or at least a reverse flow parallel while I was at it. I will be changing mine when I get the time. I hope you find the diagram useful. Since you are using pressurized storage, you will have to adapt it to your own needs...
