Hey guys, after hurting my back this weekend lifting logs on my log splitter I'm strongly considering adding a log lift to it.
My splitter is a 30 ton Northstar splitter, which can go vertical, but I do not like running it that way, and I find it to be really hard on the back as well, maneuvering the logs around each time.
There's a rugged made log lift kit available, which I'm pretty sure I can make work on my splitter fitment wise.
The kit does not come with the valve/ hydraulic lines.
I was considering taking the T port from the current valve and plumbing it in the P port of the valve which would control the log lift. Then hook up the return on the T port on the second valve.
Doing that would pressurize the T port on the existing valve while the log lift is in use, and I'm not sure the valve can take this. It's a brand valve, have to check which one when I get home from work, but I'm pretty sure it's an LS series valve, and their brochure does not mention anything about this.
While doing some research I came across power beyond.
From my understanding power beyond is a sleeve you can insert in an existing valve, which allows you to run another valve in series.
Has anyone here ever done anything like this? Thoughts opinions criticisms concerns tips more than welcome.
Pictured below is my splitter, had some help from a buddy who owns a tractor, so unfortunately lifting them up like this was a one time ordeal.
Thanks in advance
Thanks in advance
