I am thinking of adding an air control to my MF Fire Nova 2 fixed burn rate stove. The air inlet to the stove is in the rear so the plan would be to hook up a make up air kit hose to the inlet and attach the other end to an hvac damper. The whole set up should be about two feet long to go from the back of the stove to the side so that the damper can be accessed. With that being said is this a bad plan to damper with a homemade air control? I figured worst case I could turn the air down too low and get some smoke back into the house. This stove can really get warm with stove top temps up around 800F at times. By slowing it down I would like to think I could control heat output and improve burn times. Has anyone tried something similar to this before?
