Looking to add a remote receiver to GF 100 DV II.
Owner's manual shows this diagram below (jotul.jpg).
Here is a picture showing the current connections (jotul2.jpg). I believe the terminal block should be rotated clockwise 90 degree to match the diagram.
Given the current orientation of the terminal block, I will connect two wires from the remote receiver to the bottom two poles on the terminal block. Since one is already occupied by the black cable going to the backside of TH, what should I do? Can I squeeze in another wire on the same pole? The wiring diagram seems to suggest that.
Once connected, where do people usually place the remote receiver? I don't see a mounting bracket next to the terminal block.
Also, I am curious as to why the black cable is connected on the back side of TH pole, as the front of TH is empty.
