Present situation: Oil fired boiler, online, unused, homemade wood fired boiler, in parralel, suppling heat.
Plan: install WVO fired diesel gensett for cogen and utilize existing baseboard system to distribute heat, using wood boiler as supplement. Eventualy I plan to intergrate a second cogen, burning wood gas.
Originaly I had planned to install the diesel genset in parralel to the existing boilers and run the engine coolant through the heat loop, with a small modine in the garage to dump ecxess heat. My brother who is a master plumber and hydronic/steam heat expert informed me that this was not a good idea, and that I should use a heat exchanger. Since I am making the system so much more involved and complex anyway, and the return on my investment should be much greater now, I am considering a primary/secondary style, with storage.
My questions to you are; 1. Is it true that I cannot run engine coolant in my baseboard system or nontoxic antifreeze in my engine?( I really don't want an antifreezed heating system any way)
2. What is the best primary/secondary loop design considering I will eventualy have four boilers online? The original Weil- Mclean will never be run by me.
3. How do I calculate how many gallons of storage is nessasary?
4. Is storage nessasary or even advisable? I will only be running the Co-gen system when I have free WVO, otherwise the wood boiler will heat the house.
5. Is there such a thing as too large a heat exchanger? I have a heat exhanger that I know is much larger than needed to cool the diesel engine. I will have to bush the ports down and also throttle the flow with a ball valve. My brother thinks a should use a propely sized H.E., but I don't see why it would matter.
Any and all comments/suggestions greatly apreciated. Thankyou.
