I installed a wood furnace and ran hot air ducts to my living room and hallway next to the bedrooms. Last year I spent $5,000
on oil. If I had continued to burn only oil this winter I could spend $6,000 to $7,000 for the heating season. I stopped using my
18 year old oil furnace from making my domestic hot water and now I only use my oil furnace for backup heat if nobody is home
to use the wood furnace. I now use an electric hot water heater for domestic hot water. I purchased 2 tons of Envi-blocks and
have approx. one cord of oak seasoned for 18 months stored in the basement. If I burned approx. 1200 gallons of oil before
installing the wood furnace and electric hot water heater, how much wood will I need to heat my house which is a ranch style
1352 square feet not including the basement. The wood furnace can heat up to 3,000 square feet. My house has new thermopane
windows and R-49 attic insulation in 464 of the total 1352 square feet, and less insulation in the rest of the attic as the house was
built for electric heat in 1970 and five years ago built the addition. The wood furnace does not heat the basement with the exception of the flue pipe. I really don't want to use the oil furnace except if I'm at work and the house temperature dips blow 50 degrees.
I pick up unwanted wooden pallets at work and cut them up to burn. 7 to 10 pallets per week are available (hardwood).
