Hi All
First of all, lets me start of by saying that this is the best website i have come across. Its very informative
!!. About two months ago i scored a Royall indoor add one wood boiler on craig's list for $250. Of course i need help in deciding how to install it.... first pic shows what the boiler looks like (of course since this boiler is old i would have to check for leaks). Since the boiler in my house is in the garage, i would have to add the add on wood boiler in the garage. The add on wood boiler would be about 5 feet away from the original boiler. If you look at pic #2, you will see where the original vent for where the boiler is mounted. On the right side of it, thats where i would like to drill the hole for the add on wood boiler vent. Pic #3 is a pic from outside the house, in this pic you will see the vent for the original boiler,around this area the new vent will come out for the add on wood boiler. Pic #4 you will see the chimney for the fireplace, i would like to cut a hole in the chimney and bring up a new vent pipe for the add on wood boiler. So in this chimney there will be two vents one for the fireplace and one for the add on wood boiler. Im not sure if this would meet or exceed all local, state and requlatory requirements?????
Thank You,
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thank You,
