Cutting my smoke shelf out of heatform… front done still have to cut the top. Plan was to bend a steel plate with a flat back and triangular flag off each side to reseal the hole and make a sort of chase. Installer doesn’t mind but he really thinks it’s unnecessary as the blaze king Sirocco we’re putting in there already has a convection chamber up the back so it really doesn’t put off much heat in the back both from a safety standpoint and also from keeping my heatform vents functional. Of course I think the 45 degree elbow on the back of the stove will be single wall? His vote is just to cut out the top and fill the cavity with insulation. Thoughts?
Interior chimney with (I think) 6” of block behind the heatform and plenty of combustibles touching chimney. Going with a 6” insulated liner.
19.5 ft chimney from the top of the stove. Just poured the crown! No more weird chimney pipe extension!
![Add a steel plate or no? Add a steel plate or no?](https://www.hearth.com/talk/data/attachments/283/283082-c78c2bcef216e5c69cb598fb42ff671f.jpg)
![Add a steel plate or no? Add a steel plate or no?](https://www.hearth.com/talk/data/attachments/283/283080-83c341dd454f8086d2c0d65b3a50ff42.jpg)
![Add a steel plate or no? Add a steel plate or no?](https://www.hearth.com/talk/data/attachments/283/283081-5cadcc846dab8bdc3881c055ded822af.jpg)
