accent painting on Trex
RustyShackleford
1,367
NC
I would like to paint a bright red or orange stripe, about 1" wide on the edge of a step made of Trex. I've googled a bit, but most people are talking about staining instead of painting, and doing it on an entire deck. I just want this for safety. So I'm wondering what paint will stick best and also wear best (given foot-traffic wear).
Thanks.
How about that new Krylon spray paint that is designed to bond to plastic?
why not put a traction tape along the edge?
Reactions: fossil and ironpony
I like the idea of the traction tape but I do question how well it will bond with the trex. Trex is a wood fiber poly plastic combo that is not really a very smooth surface. The very surface will also expand and contract slightly with weather (it has exposed wood fibers and can absorb water at the very surface.). I have a little over 500 sqft of trex decking and have had it for quite a few years now. If it were me, I think I might go the way of the rattle can with the idea that re-application may be required on occasion.
I figure if it is 50% plastic, that will be plenty to grab onto for an outdoor application adhesive....And I suspect the tape is stretchy enough to accomodate expansion and contraction.
I would be willing to try it but on the other hand won't be overly surprised if it has premature failure. For 20 bean pods its worth a shot.
Course an 8oz can of some high-quality enamel would be a lot cheaper. Thanks for the suggestion and link though, Woodgeek.
Perhaps one could smooth out the grain in the to be taped down area with a belt sander so that there is a better contact surface?
Hmmm...not sure that would work. Its kinda like sanding drywall mud until you hit the paper - it will just continue to "fuzz" up. The only time I have seen a smooth edge on this stuff is if it was cut with a metal blade. Maybe a light touch with a hand planner??
I'm a big fan of marine coatings for outdoor applications like this. The Interlux Pre-Kote + 1-part topside with some Awl-Grip thrown in for traction, is where I'd be focusing my search. Call Interlux tech or Jamestown Distributors for specific recommendations. I suspect any paint or adhesive on Trex will fail without a chemical prep / deglosser.
Maybe attach tape to, or paint, a metal strip which is then attached to the step. I'm assuming you're talking about the vertical edge of the step here.
Reactions: woodgeek
I love the internet sometimes......I was about to suggest using stainless steel for the metal strip!
I suspect Rusty has gotten the answer to his question! ;lol;lol
Could work.
No, just as much the horizontal surface right where it drops off, as you're coming down; it's just a single step between an interior finish floor and a deck, see:
https://www.hearth.com/talk/threads/stair-design-for-an-exterior-door.112036/
... post #11. I've noticed that your eye doesn't really pick up the dropoff - something to do with the parallel edges of Trex gap above and below the riser. It's unsettling to me even though I'm used to it, potentially a hazard to someone unfamiliar.
