The room the heater is in is approximately 250 sq. ft of a converted 3 season porch so it is 3 walls of glass and gets a bit cool in the winter. It is somewhat open to rest of the main floor.Let us know how it does and some more details on how many sq feet you are heating with it. Would also love to know the story on why the stones sat for 22 years.
That is correct. Later I can try to post a sketch of how the gases flow through this particular heater.Never quite followed how they operate and the exhaust gas flow in one of those but always wondered how you clean them out. Are those two bungs for that?
The exhaust is routed through the stone mass to extract as much heat as possible. You burn a short, hot fire to heat the stone, then the fire burns out but the stone releases heat into the space for many hours. With small, dry wood and the hot fires, I wouldn't think you would have to clean the flue much at all. My BIL has a Russian fireplace, I'll have to ask him about this.Never quite followed how they operate and the exhaust gas flow in one of those but always wondered how you clean them out.
Exactly what I was thinking. I also decided to leave the door as is whit all of its knicks and rough spots.Thanks for posting. I love Tulikivi heaters and wanted to put one in our house. Cost and soft soil under the proposed location thwarted those plans. It's great that you were able to rescue and rebuild this treasure. The knicks and scratches add character and are part of the interesting history of the heater.
PS: I rotated the images for you but can't change your avatar picture. If you copy the properly oriented pic to your computer that can be used to replace the sleeping avatar, maybe with a little cropping. Let me know if you need help.
This is the part I wonder about. How to clean all the passages which don't seem too accessible. If the stone extracts all the heat then the exhaust temps should be low. Even at startup before things warm up there must be a time where creosote can form.The exhaust is routed through the stone mass to extract as much heat as possible.
Not really. The idea is that they have a hot, short burn with the stove mass (bricks) absorbing the heat as the gasses go through the chambers. This will burn off any creosote that might have been created during the start of end of the burn.This is the part I wonder about. How to clean all the passages which don't seem too accessible. If the stone extracts all the heat then the exhaust temps should be low. Even at startup before things warm up there must be a time where creosote can form.
Yup, I got estimates in that range or higher. No one seemed to believe me. The only way is to DIY but in Canada, you can't get it approved easily of it's DIY.I think he said his ran almost $15,000
That's gorgeous!Hey Everyone,
Hope you all will enjoy this Tulikivi I just finished the assembly on. After years sitting in pieces out in the woods and unloved I was able to assemble this gorgeous heater the way it was meant to be when the stones were originally cut in 1994.
Thank you
View attachment 173270 View attachment 173271 View attachment 173272 View attachment 173273
I didn't really keep track of the hours but it was probably 30+ because I did not have any plans and it took a lot of time trying to figure out the design of the firebox and gas channels. I was able to get some outside help to figure the proper design of the heater. The Chimney run also got complicated.If you don't mind me asking, how many hours do you have into this build and what was your final cost?
IThe gentleman who I got it from was a family friend and used to install these. He used this particular heater as a display for home shows. I was able to get it from his wife after he passed.What crazy circumstances led to this work of art being left in pieces in the woods?![]()
