I'm thinking about putting an OAK on the P-38 but this won't be a straight line install.
I have a slider style window next to the stove and am thinking of running the flex tube to it.
The window is 5 feet off the ground and to the right of stove, so the flex tube will rise up to that height.
Will I get good draw by doing this. Or will the OAK work like it should.
The reasoning behind this is:
With having the wood stove as a back up. I really don't want to have to put hole in the wall.
This way I can just pull the OAK out and then reinstall when needed. ( 10 minutes )
Just like I do with the A.C unit that goes there in the summer.
It won't be a pretty install with the flex tube running up instead of straight out
The flex tube will be 6' - 8' long.
