Hello!
Since I've been heating with wood for the past 37 years, I figure it's about time I stopped in here for a visit! I was part of the "back-to-the-land" throng in the early '70's -- who moved from the city to some (far too) remote land. I came with a VW full of tools, books, a pair of Golden Retrievers, and the strange notion that an Ashley woodstove was the only way to go. That's what happens when your main sources of information are Mother Earth News #1 and the Whole Earth Catalog...
After being nearly driven out of the small cabin I built by the oversized Ashley, I settled in with a Waterford 101 which served me faithfully for many years--even after building my present house--a small 2-storey heavily insulated frame structure with barely 800 square feet of living area. For the past 18 years, I've been very cozy with a Jotul Alpha stove: a catalytic convection-type heater which evenly heats the entire house in style.
![A Little Yodel From My Jotul... A Little Yodel From My Jotul...](https://www.hearth.com/talk/attachments/f_jotulm_296a4e0-jpg.180564/)
The house has a good bit of thermal mass--and it heats slowly and cools very slowly. The centrally located chimney is insulated stainless and was set up to be cleaned from inside the house. I anticipated that I would not be enthusiastic about getting on the roof in my later years. In the picture, you can see the strange bit of plumbing with the single-wall pipe before entering the tall chimney. I am able to open the Tee and get fiberglass cleaning rods to push a brush up and down the chimney. Some time ago, I removed the chimney cap and have noticed no negative effects--and indeed even more draft (although draft has never been any sort of problem with a 2-storey chimney...)
The stove sits on quarry tile and is located fairly near a wood post which I have shielded with some 1/4" plate aluminum held off the wood surface with some ceramic spacers... it's never been a problem.
This week I sent off for a Condor SteelCat combustor in a never ending quest to squeeze more BTUs out of each stick of oak. I'm also replacing the rather thick padding Jotul used around the combustor with some ceramic fiber blanket material available on the web from kiln supply shops.
I really like the Jotul Alpha--although I think the glass window is far too large. I may have been tempted several times over the years to try out a different stove, but then I reconsidered after noticing the general deterioration of manufacturing standards, the usual horror stories, and the clear memory of what a bear it was to get this big chunk of cast iron into its present location.
I'd chat some more, but I must get some more firewood stacking done before the noon sun makes it too much of a chore... another half-cord and the wood shed will be filled--nearly a 3-year supply. To my way of thinking, that's even nicer than money in the bank.
Gene
Gene
