mtarbert said:
I have a friend who has bought a farm in northern Harford county,Maryland. I live 8 miles from the farm. When I talked to him yesterday about cutting some of the less than healthy trees he told me to take whatever I wanted. So....thinking ahead I get him to jump in my truck so we can mark what he is willing to let me have. I bring a can of spray paint and start Xing heck he would have let me clear cut the site but I really want to save as much as I can that are healthy. I'm going to fell buck and split and haul home everything I cut . Would it be greedy of me to take as much as I can even if it would not be burned for 8years? The trees marked are Cherry,white oak, hickory and ash 24-30inches across
It seems to me that
the key to this whole thing is not what you want but what the owner wants, not what you want. If he wants x many trees cut, then if you can use them you should figure on cutting x number of trees. It seems to me that greed has absolutely no part in this transaction. After all, he told you which ones he wants out.
On the other hand, after cutting for a time, I would than double check with the man and have him look to make sure he still wanted the rest of the trees taken out.
As far as the wood keeping 8 years, I have no problem with that at all and have done it for many years, however I do cover the top of the piles because leaving wood that long out in the weather will potentially make some of the wood go punky by the time you use it. But cover the top and there should be no problem. Also, while you are cutting, cut some poles; either from limbs or some saplings (with permission) and lay those down under your wood before stacking. This will avoid contact with the ground, allow air circulation under the stack and will keep the wood from going bad.
Good luck.
