Hello All
First, I'd like to report on an issue I just ran into using a Dayton 1TDP5 blower in my 25 EPI Stove. I previously went thru 2 OEM blowers within 5 years. The failure was just an unbearable amount of noise from the OEM blowers. For the last 2 years, I've run the Dayton split capacitor motor without issue. Last weekend, I blew them main board fuse so I installed a new fuse and using diagnostic mode, determined the convection motor to be the cause. Upon removal, I found the issue. Apparently, I had not noticed the wires for the capacitor were close to or maybe resting on the igniter housing that protrudes from the firewall of the stove. The wires were melted and hanging on by a few wire strands!
With that said, I did order a new OEM motor (Though I personally think they suck.) The Dayton motor was so much quieter in operation. My question is this, I can repair the wires on the capacitor but can the capacitor be moved to another position on the motor? Also, has anyone run into other issues running the split capacitor motor vs the original shaded pole (Other than melted wires
) I should have checked that with a mirror evidently. The Dayton motor seemed to function just fine. Motor changed speed with board controls. I've read a few claims that they can ruin circuit boards. Not sure if that is just fake news or not. I was planning on repairing it and using a a spare if I can get the wires moved or at least protected from heat.
Let me know your thoughts.
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
