I
ISeeDeadBTUs
Guest
Thursday November 29. The last time the hydronic was loaded was last night, approx 10PM. Hopefully you can see that we are running 'VSF' (visibly smoke-free). Since it is warm outside and the Mrs has left for work, there is very little heat demand at the moment. Thus, while I opened the feed door to shoot the pics and rake the coals, I will not be adding fuel for a while.
7:36AM
The damper is currently closed.
I know NoFo and I will disagree on this, but why would you want this in your house?
A hot fire will make the ceramic glow.
8:27AM, still 'VSF'
Damper open. Aquastat set about 173, 10 deg variable. Factory recommended steting 180
Leak at the GW temp sensor.
GW standby heat losses dry/warm wood in shed.
Note leak, copper into Therma-PEX.
Right side of GW.
For those that asked about the chimney . . . a "T" plus three sections of Metalbestos. No rain cap.
, 10:39AM A snapshot of the inside stuff.
Boiler plenty warm.
Too warm in NY
DHW stabdby loss 5 deg since 6:30AM
Goal: Lets see <1470 hours on April 1, 2008 :coolsmirk:
I save so much oil I have to let some leak!
50-plate HX and strapon aquastat.
11:18AM Time to load.
PRE-Load.
Warm day=small load
After raking and an oxygen rush
POST-Load.
3 mins after loading
4 min
9 min
14 min
20 min
23 min
Perspective approx 90' away
30 min
Back to VSF 33 min after loading
Still VSF
Damper closed 1 hour after loading
'Idling'
Idling viewed through triple pane and external screen, appox 80' away
7:36AM
8:27AM, still 'VSF'
Right side of GW.
Boiler plenty warm.
Too warm in NY
PRE-Load.
Warm day=small load
POST-Load.
4 min
9 min
14 min
20 min
23 min
30 min
Still VSF
'Idling'
