After reading several different threads that mentioned the temperature inside the firebox I became confused (which occurs way too frequently these days) about what the ideal temperature should be. My stove has a temperature gauge that sticks down into the center of the stove's top. I often see temperatures between 1,000° F and 1,200° F on this gauge which is way hotter than what I have been reading here. So, my question is this: When you all report temperatures are you using Celsius or Fahrenheit? Also, do most of you use a magnetic temperature gauge on the outside which, in my mind, would provide a lower temperature than one inside the firebox?
